It is currently Tue Sep 09, 2025 10:32 am
 Post subject: Completely dead
PostPosted: Sun Sep 03, 2017 8:44 am
I turn the ignition and nothing happens,the batteries are on...... any ideas?
 Post subject: Re: Completely dead
PostPosted: Sun Sep 03, 2017 10:18 am
Is it in gear? It won't start then....
2014 A22
PostPosted: Sun Sep 03, 2017 10:26 am
Did the kill lanyard get pulled on?
PostPosted: Tue Sep 05, 2017 5:47 am
Year/Motor?
PostPosted: Sat Sep 09, 2017 11:59 am
Make sure your battery cables are tight. I had mine randomly come loose on both batteries at about 200 hrs
 Post subject: A couple of questions...
PostPosted: Sat Sep 09, 2017 12:38 pm
By completely dead I suppose you mean nothing happens at all. But I am not sure. So here is a list of questions that will help to tie this down a little better.
If you turn the key to the ON position, does anything come on? Gauges? How about the radio? If nothing comes on, the problem is between the batter and the dash board in cables, fuses, and such. Make sure you also verify ground cables. Use a meter to find the "open".
If the above works and the gauges wake up but the engine does not crank, check neutral safety switch and lanyard first.
With those new clues, it will be easier to guide through the trouble shooting...
Users browsing this forum: No registered users and 118 guests
