It is currently Thu Sep 11, 2025 3:42 am
Post new topic Reply to topic  [ 33 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: Cooler
PostPosted: Fri Feb 26, 2016 2:59 am
2016A22inCO wrote:
Noticed the same thing last weekend when checking out the new A22. Obviously they haven't addressed the issue in the 2016's. I have the same problem as one of the other members where not only does my lid not open without having to pull the cooler out a bit but I have to remove both seat cushions because about 1in of the cooler sits under the back most corner cushion. Why offer a pricy factory option if it isn't well thought out/designed? Or at the very least let you open the dang thing?? SMH
The $100 factory Igloo cooler was available at Walmart for $32 but is no longer available. AO cooler probably best option that fits.
PostPosted: Fri Feb 26, 2016 6:13 am
You can still order the cooler online from Wal-Mart. Has anyone got a Yeti, Orca or Grizzly to fit in the space where the Igloo would go?
PostPosted: Fri Feb 26, 2016 12:10 pm
They won't fit unless it's the small one that holds like a 12 pack. There are 2 other 36qt marine coolers with shorter length, maybe that'll give you the room to open the lid.
Users browsing this forum: No registered users and 114 guests
