It is currently Thu Sep 11, 2025 12:55 pm
 Post subject: Rear PNP not filling??
PostPosted: Sat Jul 18, 2015 9:09 pm
On vacation and rear plug and play not filling. Pump is running but no water coming out of top line when disconnected. Any idea?
 Post subject: Re: Rear PNP not filling??
PostPosted: Sat Jul 18, 2015 9:59 pm
Could be a priming issue. Could also be debris. Did you take the cartridge out to make sure no debris is in it.
PostPosted: Sat Jul 18, 2015 10:18 pm
No how do you remove the cartrage? That removing whole pump?
PostPosted: Sat Jul 18, 2015 10:24 pm
Also how do u resolve priming issue if that's what it is?
PostPosted: Sat Jul 18, 2015 11:26 pm
Check to make sure valves for rear plug and play are open. They should be horizontal I believe.
14 t22 with sg
PostPosted: Sat Jul 18, 2015 11:28 pm
They are all open.. system worked great yesterday and not today and nothing was touched between. Thanks
PostPosted: Sun Jul 19, 2015 10:28 am
Had seaweed up in the pickup tube. Hopefully that was all. Thanks
PostPosted: Sun Jul 19, 2015 12:33 pm
I have priming issue with my 15 T22 front pump. Doesn't pull water in unless I start moving forward, then pump pushes water just fine.
Anything I can do to address the self priming problem?
Users browsing this forum: Google [Bot] and 73 guests
