It is currently Thu Sep 11, 2025 11:30 am
[ 5 posts ] |
Author |
ban-ls1
Post subject: Swivel rack not staying in place. Posted: Thu May 21, 2015 6:26 am |
Team Axis |
Joined: Tue Jun 14, 2011 7:19 pm Posts: 64 Location: Jefferson, Ga
I'm not sure if this is already been covered but on my 2011 vandal the swivel rack on the driver side will not stay in place. with two boards on it it'll swing inside the boat and hit someone in the head if you're not careful. it seems as if the spring that holds the pin tight is loose or broken. has anybody taken this apart to change it or repair?
Top |
PotatoShack
Post subject: Re: Swivel rack not staying in place. Posted: Thu May 21, 2015 6:41 am |
Team Axis |
Joined: Tue Aug 21, 2012 5:42 am Posts: 333 Location: College Station Texas
I know you can tighten them. I had that issue with my 2012. The dealer replaced them under warranty.
Top |
Ferral
Post subject: Re: Swivel rack not staying in place. Posted: Thu May 21, 2015 9:03 pm |
Team Axis |
I've had that problem too. I solved it by cleaning some of the grease off the release pin and out of the holes that the pin locks into. Once I did that, I never had them release on their own again.
Top |
Walter
Post subject: Re: Swivel rack not staying in place. Posted: Thu May 21, 2015 10:03 pm |
Team Axis |
Mine still does this, I always forget to clean it until I'm already on the water.
Top |
ban-ls1
Post subject: Re: Swivel rack not staying in place. Posted: Fri May 22, 2015 1:02 pm |
Team Axis |
I tightened the top and bottom allen head bolts which put more tension on the bushings which it has seemed to resolved the problem. I also cleaning up some of the grease on the pin
Top |
[ 5 posts ] |
Users browsing this forum: Google Adsense [Bot] and 60 guests |
