It is currently Mon Jul 07, 2025 10:28 am
 Post subject: Stereo on a 2014 Axis T22 AND Ballast?
PostPosted: Mon Mar 30, 2015 11:39 pm
We are having no luck playing Android phones on the stereo anyone else? :shock:
Also is there no Bluetooth on the stereo Pack2??
Ballast?? what exactly is the ballast on this boat? how much in each area?
Also What is "the leaky fitting issue (which has been resolved)" ?
Thanks in advance.
 Post subject: Re: Stereo on a 2014 Axis T22 AND Ballast?
PostPosted: Mon Mar 30, 2015 11:53 pm
Bluetooth is an option...check your build sheet if you did not order your boat. If you ordered your own boat then you should know
Axis website says 900lbs ballast so that would be the hard tanks at 500, 200, 200
"Leaky fittings" we're a design flaw on previous Sumo sacks.
Did Texas Malibu not go over boat features and functions with you on your delivery? Ed or Clark at Boardstop at the dealer know about the Sumo fitting issue and would've explained "the fix" if you had gotten those effected sacks but those sacks should be all gone out of Straightline's stock that's if you got Sumo 750 or smaller sacks. Fly High or Ronix sacks did not have any issues.
PostPosted: Thu Apr 02, 2015 8:12 am
If you are having issues with finding the Bluetooth signal, be sure to search for it within the first 30-60 seconds of applying power to the stereo. After that it stops broadcasting I guess, assumes you are using a different source.
I thought mine was broken but it turns out that this was the case. Kind of weird, I'm used to vehicle Bluetooth being on all the time
2014 A22
