It is currently Thu Sep 11, 2025 7:39 am
 Post subject: Front arrow bag not draining well. Help
PostPosted: Mon May 05, 2014 12:00 pm
It will drain but really slow not sure what is causing the issue.
2013 A22
 Post subject: Re: Front arrow bag not draining well. Help
PostPosted: Mon May 05, 2014 12:14 pm
Check and trace your drain hose. Might be a little too long and is looping causing an air pocket. The hose should only be just long enough.
PostPosted: Mon May 05, 2014 2:25 pm
make sure they didn't put the drain in the wrong place .... dealer put my drain on top. Some how it still drained but it was super slow
PostPosted: Mon May 05, 2014 5:11 pm
Thanks I'll check that stuff out
2013 A22
PostPosted: Mon May 05, 2014 7:19 pm
I had the same problem as amsugg, much better after I switched the hoses
